Domino 30H HD2+
Discussion in 'Projectors, Screens & Video Processors' started by sye7euk, Nov 4, 2004.
  1. sye7euk
    sye7euk
    I have just got a Domino 30H that should I think have the HD2+ chip fitted. Is there any way I can tell in the menu or somewhere that it is actuly fitted?
    Thanks :rolleyes:
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Your dealer should be able to tell you.
    If he can't, ring Sim2 on 01825 750850 with the serial number and ask them to check.
    The dimple fix on the HD2+ chip makes the spot in the middle of each mirror much less visible. On the new Sim2 HT300E the DarkChip3 DMD gets rid of the dimple completely.
    Jeff :rtfm:
  3. sye7euk
    sye7euk
    The dealer said it was and I have know reason not to beleive him but I would like to know how to check if possible?
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    I've just edited my reply above.
    On the HD2+ chip the dimple will be faint but visible.
    On the HD2 it is very noticeable.
    Jeff :rtfm:
