domino 20 or 30
Discussion in 'Projectors, Screens & Video Processors' started by Geordie Bry, Jun 27, 2004.
  1. Geordie Bry
    Geordie Bry
    Jun 27, 2004
    1,036
    +64
    want to upgrade current projector sanyo z1 owl othello 6ft wide motorized screen going to convert loft into home cinema so wife gets living room back i might have to buy 30 because of shorter throw is it 2 k better than 20 and how much better than sanyo would be gratefull of any advice panny32pd30 bwcdm7nt fronts cdm cnt cdmnt sub cdmnt rear surrounds bw in wall rear cnt rotel rsp1066 1075 5channel 1070 2 channel dvd marantz 8300 sky+
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Bryan,
    The 30 is a better choice if you are likely to be using High Def material in the future in the form of Euro 1080, D-Theater, HCPC, and eventually High Def DVD.
    As you said, the 30 has a shorter throw which is 1.8 to 2.4:1 as opposed to the 20 which is 2.2 to 3.1:1.
    Jeff
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,857
    87
    Newcastle
    +122
    Can you expand a little you answer please.
    Are you saying that 1024x576 is better with the current crop of players due to the line resolution.
    If you were feeding it a 720p signal (Say thro a scaller) then the 30 is better
  4. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    thats about right.
    Domino 20 is a perfect match for SD material.
    the 30 will still deliver a great pic with SD but it will realy shine when HI-DEF is around
    the 30 will is also be a great match for dvd players that scale to 720p such as the pioneer 868i or denon A11
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,857
    87
    Newcastle
    +122
    Or a scaller like the iscan HD ;)
  6. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    well i would rather take a lumagen but yeah as long as it 1:1 maps to the 1280x720p of the domino 30 then are in real business.
    Played hi-def through my PJ and the results were just awesome. having a true 720p source is just so much better than scaling to 720p. The difference is staggering.
    But if you had a domino20 it would be downscaling the 720p source which is not good
