Domino 18 lack of info
Discussion in 'Projectors, Screens & Video Processors' started by davee, Mar 14, 2005.
  1. davee
    davee
    Jun 15, 2004
    717
    twickenham
    +57
    Any reason why there seems to be such a a lack of spec info on the Domino 18? It would appear to be a 6 segment color wheel but nowhere can I find the speed or rpm of the wheel. The lamp is rated at half the wattage of the Infocus 5700 yet both are long throw projectors. Does this make for a proportionately dull image in comparison?
    Yes I know I should demo it but some basic info would be a start. :lease:
  2. thedoc
    thedoc
    Aug 22, 2003
    262
    16
    As for specs, Jeff or Alan here will help I am sure...
    ...BUT test & compare different machines with your eyes.
    I have been surprised to find sometimes the specification underdog, can look and outperform other projectors that on paper you might think outclassed it.
    :smashin:
  3. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    davee
    The Sim2 Domino 18 has a six segment 5 speed colour wheel so colour separation will not be an issue for the majority of viewers.
    Although a 120w lamp is used, the light engine is very efficient giving a much brighter image than you would expect from such a lamp.
    In a light controlled room the Domino 18 will display deeper blacks and a higher contrast picture than the 5700.
    Jeff :rtfm:
