DolbyTrueHD & AVR300
182
Hopfully someone here can confirm one way or another if i can connect my HD-DVD player with the anologue outputs to my AVR300 to get DolbytrueHD?
I know the HD-DVD player isn't capable of outputting it yet but that should be sorted soon with a firmware update. I'm guessing the AVR300 is not capable, but would just like to know for sure. Is the AVR350 able to proccess it via HDMI? If so I may concider an upgrade.
Thanks :thumbsup:
klacey
If it has 6 analoginputs then yes, along with doldy digital plus. Apparently the new firmware v2 is coming out tomorrow, just a rumor
182
Thanks Klacey.
Oh thats good news! Yes i'm pretty sure it does have six anologue inputs. Yeah i heard the updated was due this week.
klacey
I will let you know if i hear of an update, its meant to let you decode true hd in 5.1 instead of the 2 channel we now have.
Fingers crossed.
thatMikeguy
Wow, that is the first I have heard of this. I had actually heard that it was not going to be possible without significant internal changes... Hope you are right. Crusty/ Webhammer heard anything about this?
M.
Greggles
No current processor/amp can decode "True HD" sound, but if the player has internal decoding and outputs via 6 channel analogue (as all first generation players will have) then any processor/ amp with suitable connections can "play" it.
Crustyloafer
M.
I think you are getting slightly confused here, they are discussing the possibility of the players being able to decode and output a True HD soundtrack, they are not claiming that the Arcam processors can be upgraded to do this themselves, this will not happen.
thatMikeguy
Tee hee... I thought it was too good to be true. Well good luck with those HD players guys. I'll stick in the world of SD with the DV29!
Mike
182
Yes the HD-DVD player does the proccessing, so all the amp does is, well, amplify it. So good news, and the 2.0 firmware should be enabling truehd audio, so all is good :smashin:
182
To anyone thats interested. I've now got my HD-DVD player outputting trueHD now and it sounds excellent through the AVR300. :thumbsup:
videoaddikt
Thanks :thumbsup:
Was this ever resolved? I thought with the latest firmware (Toshiba) HD DVD players decoded TrueHD but it can only be output via HDMI or Analog 5.1, not optical.
ianmacd
"Apparently", the toslink connector (well protocol really, I guess) does not have enough bandwidth to cope with 5.1 LPCM so you will only get 2.0 LPCM, DD or DTS over the toslink cable.
videoaddikt
Pardon my poorly phrased question. It had more to do with the capability of the HD DVD (or Blue Ray) player. I believe all HD players now decode TrueHD on board and output it on 5.1 analog (as well as HDMI for those receivers that can use them.)
proux
Yes, the EP35 (but NOT EP30) decodes Dolby Digital Plus / TrueHD (IF the movie has it!), outputs it via 5.1 (NOT optical) and sounds fab!
Similar with HDMI- I think outputs LPCM(?) for amp decoding, but check HD-DVD forum.
Trending threads
