dolby vs pcm on denon 3805
Discussion in 'AV Receivers & Amplifiers' started by phillfyspoon, Aug 12, 2004.
Tags:
  1. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    If i was to convert an audio cd to dolby stereo (48khz/24bit 640kbps) would it sound better because it is using denon's dolby decoder rather then the pcm one? i would of thought a home cinema amp would have better dolby decoding. The reason I want to do this is to create an audio-dvd.
    I managed to get michael jackson dangerous in dts it was created from the orginal audiocd and sounded better then my original It must be something to do with the dts decoder being better then the pcm decoding.
    any insight?
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    I might be wrong :blush: but I am sure the amp doesnt convert your cd's into DTS. Its just adding some kind of DSP.
    Whats your amp set to? Input, Mode (DTS NEO6/DD 5.1 cinema/music ect.).
  3. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    no u got me wrong it is in dts it is a dts audio cd. on the display it says dts surround. it isnt a dsp.
  4. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
  5. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    i will explain the process. I rip a ordinary music cd to hard drive. I use a dolby digital encoder to make it dolby stereo (48khz/24bit) i then put it to a cd and play in dvd player. It is now dolby digital
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Dolby uses lossy compression methods, therefore converting a CD to Dolby Stereo will resuly in loss if information and will not sound as good as the CD. DTS audio is also a lossy compression method and therefore still not techically as good as an orginal CD. If you want to get bettr quality than CD then I suggest you buy a DVD-A or SACD discs (which are not available for that album) or get the album on vinyl.
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Ah, I see :thumbsup:
    I have no idea :laugh: :laugh: :laugh:
    PS I used to live in Alverstoke.
  8. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I see what u mean I know technicly im not going to get better sound then an uncompressed wav but what im saying is to me it sounds better in dts format because the amp is better at decoding a dts signal then a normal pcm signal. all av amps sound better in dolby, dts then they do with cd audio right? so I think it would be worth converting my favourate albums onto a dvd disc in dts or dolby. do you see what im getting at.
  9. Jules
    Jules
    Oct 11, 2000
    5,580
    134
    +1,039
    Wrong.
    If I record a CD to a DVD disc on my Panasonic E60 DVD player, the resulting DD 2.0 audio recording is noticeably inferior to the original CD.
  10. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Better than a lot of DVD players, but not better than CD-Audio/PCM decoding.
    No, CD-Audio is uncompressed PCM so it will sound better than a compressed DD or DTS track.
    DD wasn't meant for (high-end) music anyhow, it's for multi-channel audio. DD can give good results with music though, at least on commercial DVDs.
  11. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    ok maybe not dolby but dts encoded at 1.5mbps sounded better then the pcm original for sure. My system is more suited to deal with dts then pcm that must be the reason it sounds better I know i can not improve on the pcm in anyway but because the denon was designed for dts it sounds better in it.
  12. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Is it possible that the DTS and PCM recordings differ in the volume levels per channel, i.e. you did not compensate for that at the AV amp when listening to them? (A higher volume is often perceived as "better" sound)
    As well such tests are very subjective and if not done as double-blind test then it would not give a reliable result, but if you are happy with it then that's fine, too. :)
  13. ktng
    ktng
    May 9, 2004
    174
    16
    UK
    Well the Dangerous cd you have has been (re)processed into DTS using one of a number of techniques available to produce a DTS cd from a stereo source. This will produce a totally different result to just encoding it as DD or DTS. I suspect this (re)processed DTS cd is still technically inferior to the original pcm cd, but may well 'sound better' to you as it has the added centre channel/surround effects which although they have been added synthetically are much more effective/prominent than either DPL2 or DTS Neo6. I've just listened to both of them in straight stereo as well and the DTS version does 'sound better', but it's probably because of the increased volume and the reprocessing of the normal stereo channels that also happens when it is processed into DTS.
    So I think if you can reprocess your CD's to DTS rather than just encoding them to either DTS or DD stereo (not sure you can just encode them to DTS anyway) then they may well sound better to you. But from what I've read it's not an exact science and if you convert cd1 with method A it may sound great and then convert cd2 with the same method it may sound terrible; so you may have to convert each cd with 2, 3 or even 4 different methods before you find one that sounds 'better' than the original.
  14. mick23
    mick23
    Mar 20, 2002
    801
    uk
    interesting thread this.
    i have (the eagles hell freezes over on dvd ) which has option of dts or pcm am i correct that if i only owned a dvd player that the pcm vertion would be the same as if it were a bog standard cd but playable on a dvd player???
    i also have the best of the eagles on older cd and a remastered vertion if however playing say hotel california on dvd player "dts option" in 5 channel replay because its taken from a live recording and you have the addition of center and rears as ktng mentions you have more sound and possible a differant mix,
    if playing say same track on cd player with normal cd vertion wether its sounds slightly differant because its 2 channel only non dts or 2 speakers vs 5
    thank you
  15. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Can't say for certain if it's the same as the CD since you don't know what master it was taken from. Or it is for example possible that the DVD PCM track has been recorded with Dolby Surround into it while the CD doesn't have that.
  16. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Maybe the "problem" is the player, most DVD players dont play CDs (PCM) very well...
  17. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I still think dts sounds better then PCM on the denon 3805. in stereo that is.
  18. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +599
    if its DTS 96/24 then it will definitely sound better than CD which is 44/16...lol
    edit: oh, and regardless of the recording method/level, format or media, if it sounds better to you, then it is better....i would have thought that a simple thing to understand, even if from a purely on paper technical viewpoint it shouldnt...heh
  19. musicman1999
    musicman1999
    even 1.5k bit rate dts,has a lower bit rate than pcm stereo(768,000 bit per channel).Try hooking up a good cd player to the 3805 analog hookup and you will hear the difference.Oh,also use the analog bypass on the 3805,it should not even be close.
    bill
  20. joffy1780
    joffy1780
    Dec 19, 2004
    1,407
    Washington,Tyne and Wear
    +75
    I get the feeling people aren't getting what you're saying.
    Why don't you give it a try and come back with your opinions,should be quite interesting ;) .
