Drdense
I know this has been discussed before but I cannot find the information specific to my issue.
I have a Panasonic DP-UB450 with the video output connected to a Philips 65OLED+936 and the audio to a Pioneer vsx-933 receiver.
When playing (any) 4K blurry with Dolby Vision the screen is constantly flickering between the picture and black (the Dolby Vision notification keeps popping up also)
Both HDR10 and HDR10+ are fine. I have checked the HDMI with known ultra speed cables, no difference. I have confirmed that all settings on both the player and the TV are correct. It works OK if I disconnect the audio HDMI but this is not an acceptable fix As I have discs with HDR10+ which this receiver cannot pass through. Firmware is up to date and I have tried plugging the HDMI into different ports on the TV but still the same (and enhanced HDMI is definitely turned on)
Is this bluray player unable to pass Dolby Vision correctly when the audio HDMI is in use? (If so that is a serious design flaw)
I also noticed that the Bit Depth is showing (on the tv stats) to only be 8-bit RGB for Dolby Vision but full 12-bit YCbCr 4:2:0 for everything else.
