Dolby ProLogic II from a mono sound source?
Discussion in 'TVs' started by bedders, May 2, 2003.
  1. bedders
    bedders
    Apr 29, 2003
    219
    UK
    Sony 14" mono TV - use small phone headphone to L and R Audio input into a Sony DAV-S550 audio in.
    How will Dolby ProLogic II react/sound on a full 5.1 set of speakers?
    Will it work, but only put the same mono out both L and R speakers, or will there be no rear sound, just front?
    Many thanks for your advice :)
  2. Jase
    Jase
    Mar 16, 2001
    9,530
    UK
    +930
    More than likely you will only get sound from the centre speaker. You need a Stereo or Dolby Surround signal for it to work properly.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,067
    ProLogic (and DTS Neo6) works by using differences between the left and right channel signals to steer sound to the various speakers. Anything that is identical in both channels (typically, dialogue in a stereo signal) is routed to the centre where it belongs.
    Clearly, if the entire sound is identical in both channels (as it would be for a mono signal) then the entire sound is routed to the centre.
    Many amps have other surround 'modes' that process signals, including mono ones, differently.
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Nikbedwell
    Have you got a video if you have use the audio out to connect to your dav550 then you will get your tv in prologic{thats if your vcr is a nicam model}.Hope this helps.
    Gonzo.:)
