Im sure this cant be right!
Setup:
- Pioneer vsx-916 amp
- Pioneer S-V410 5.1 speakers
- Freeview box outputs component video and optical audio into the amp (although the actual transmission audio is stereo)
So heres my problem, when watching normal tv, if I put the amp into Dolby Pro Logic mode, my rear surround speakers play up. Most of the sound comes through fine, but the voices when people are speaking on the tv come through really low volume and chirpy almost the same sounds as a volume fax transmission but very muffled so its not so ear piercing. Theres absolutely no chance of making out whats being said, its merely just an extremely low volume chirping (but in time with the speaking on the tv).
All audio (including voices) come through fine on most of the other preset modes (i.e. the music, movie, cinema preset etc.). Also, Ive tested Dolby Pro Logic on other sources like the DVD player (optical coax connection) and that comes through fine.
I tried disconnecting the cabling and re-cutting the cable connections but no change. I then tried adjusting settings on the amp but still nothing.
Originally I was having this problem with the front Left & Right as well but when I changed a setting called dialogue to ON this has solved it with the fronts, but the rears are still playing up.
In addition, Ive noticed that when I turn my amp on after leaving it off overnight I get a buzz from all speakers for about 10-15 seconds. Im not sure if the 2 things are linked ?
Im really cant pin point this
. Any ideas anyone?
Setup:
