Dolby Pro Logic I
Discussion in 'Home Cinema Buying & Building' started by polyvision, Dec 30, 2003.
  1. polyvision
    polyvision
    I have three types of sound selection on my amp which are dolby digital (for 5.1), pro-logic, and digital. When I connected the system via sky I found that pro-logic only worked well on certain scenes and on others there tended to be distortion in the rear surround speakers. Is this normal? Also, I found that the digital option (which basically keeps all speakers on and adapts to mono or stereo broadcasts) worked more effectively with no distortion.
