Is there a difference between the encoding that Dolby Live on the Mystique soundcard does on a 2 channel source and the Dolby Pro Logic II processing that my amp does on a 2 channel source?
I'm outputting audio from my PC via a Mystique soundcard into my amp so do I want to enable Live, which will just send the amp into Dolby-digital mode or do I disable Live and set my amp to use Dolby PLII processing?
slink
slink
