Dolby Headphone Question
Discussion in 'TAG McLaren Audio Owners' Forum' started by sam3k, Jun 10, 2004.
  1. sam3k
    sam3k
    Oct 29, 2002
    13
    Is it possible to have the Dolby Headphone processing output via the tape out at line level, rather than the zone 2 output? Basically I'd like to use a headphone amp and having two volume controls wouldn't be the best.
    Sam.
  2. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Hi Sam,
    You need to switch to zone 2 to get Dolby Headphone modes as DH processing is not allowed on main zone outputs.
    On the tape out you will find that the output gain will change depending on what post processing is being applied and in the case of Dolby Digital the dialog normalisation of the recording. This is because the tape out feed is pre-volume control chips, while zone 2 and main outputs are post volume control chips. The volume control chips are used not only for setting the user volume but also analog domain headroom compensations in the system (+a wealth of other trims).
    I use a pair of Stax 007T electrostatic headphones on Zone2. I set the zone 2 initial volume in the menu up as +4dB to drive the energiser inputs properly and then use the the volume control on the Stax energiser to decide how quickly I become deaf!
  3. Miron
    Miron
    Sep 26, 2002
    1,416
    Vienna, Austria
    +49
    Steve,
    I am not sure if I understood it correctly. Does this apply for 5.1 AV32R DP too?
    In other words, on 5.1 AV32R DP where you do not have zone2 output you have to connect it somehow!
    thanks
  4. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    On the 32DP it has the concept of a virtual zone 2, that is you can assign a pair of the primary zone outputs to act as the zone 2 feed when zone 2 is selected. As all those outputs have volume controls on them the output will be at the correct gain. If you take it from the tape out then the output gain won't be consistent from format to format as mentioned above. It's OK if you just listen to CD's and the like in direct mode though.
  5. sam3k
    sam3k
    Oct 29, 2002
    13
    Thanks for the reply Steve.
    I remember on the old forum people also recommended that you could just plug your headphones in directly to the analogue outs (w/o a headphone amp). Does anyone happen to know where I can get the appropriate adaptor cable from?
