Dolby Digital
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jacko, Mar 3, 2001.
  1. Jacko
    Jacko
    Hi, was wondering if it is possible to get the Dolby digital working by using the pro-logic thru my tv and driving the other speakers with a seperate amplifier from the dvd. Is it possible and if so how? Go easy on me please,as I'm new to dvd.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    If your DVD has a built-in decoder (also called 5.1 output) you could run the front outs to the TV (stereo in) and the other channels to seperate amplifiers (3 channels needed) though volume control would become a kind of problem here.
    I rekon you rather stick to DPL (driven from the TV) until you decide to buy an AV amplifier (DD/DTS).
  3. Jacko
    Jacko
    Thanks for the info, think your right about using tv dpl for now, but think I'll want to get the most of DVD and my plastic will pay for amp etc. Just 1 more thing, I assume the audio comes in via scart and the tv decodes the signal ?
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The connection depends on your DVD player and TV:
    If the TV has Scart only and the DVD has Scart, too, a Scart lead would be needed.
    If the TV has analog stereo in (RCA/phono connectors) you can connect the DVD's stereo out to those.
    If the DVD does not have Scart use a stereo to Scart adapter cable.
    And yes, the TV will do the DPL decoding. If the DVD does not have a DPL soundtrack you may activate the downmix function of the DVD player, ie Dolby Digital 5.1 will be downmixed to stereo or DPL even and outputted analog (which the TV will then receive and decode).
