Dolby digital vs DTS
Discussion in 'AV Receivers & Amplifiers' started by gazzaraki, Dec 30, 2006.
  1. gazzaraki
    gazzaraki
    Dec 22, 2006
    42
    Am presently doing a trial with a Marantz SR7500 and can't believe the difference between DD and DTS.Have gone through the auto calibration with no problems.I think i have done everything right.Have found the eagles(hell freezes over the most impressive DTS with the surrounds)Any thoughts on improving my dolby digital sound with this reciever.Not running a sub.
    Sony DVP-S725d,Marantz SR7500,B&W220i and Wharfdale surrounds.
    By the way...the Marantz has altered the centre speaker from small to large.Is this ok,considering it's a small centre speaker.Any advice appreciated.
  2. sunnyb4u
    sunnyb4u
    hi there mate
    i love dolby digital especially on xbox 360 games erm as far as i know
    dts runs at a higher bit rate with more channels thus increasing sound quality
    i have actually heard both dd and dts on my amp using the same copy of lord of the rings and dts wins hands down all the time
    i believe its only time before dts will rule dd
    it reminds me of the battle between intel and amd where dts is the underdog but it sounds so much better
    but normally i am very pleased with dolby digital
    i just use dolby digital for games since they are only programmed in dd and dts for movies
  3. mistrip
    mistrip
    Aug 16, 2002
    319
    UK
    +12
    Usually you just need to turn the volume up a bit for DD to sound the same as DTS.
    And if you speaker can't deal with low frequencies (i.e. it isn't full range) it should be set to small i think.
  4. dts197
    dts197
    Aug 12, 2006
    4,890
    +653
    I'm no expert but I have to disagree with that. I think there's a bit more to it than increased volume!
  5. BazMan
    BazMan
    Nov 2, 2004
    609
    Northampton
    +25
    Can, open, worms, everywhere...
  6. Basil Plumley
    Basil Plumley
    Aug 10, 2000
    8,263
    Enjoying my system - for once!
    +723
    Carry out a search here using dolby digital dts as the keywords and you may be supprised to find out that this isn't the first thread here about the subject...in the meantime, have a look at this to see what the differences actually are...
  7. Davy
    Davy
    Apr 25, 2005
    376
    5
    Warwickshire
    +34
    DTS to DD? DTS wins everytime IMO. The only problem in this country appears to be that the DVD companies want to put 250 languages (OK I exagerate - just) onto region 2 discs, to satisfy the european market. As DTS uses a lot more disc space than DD, it gets left off in favour of all the languages. Go for American Region 1 disc - they seem to have a lot more DVD's with the DTS soundtrack on and maybe only two languages, normally English and French (ie predominantly North American languages). I bought the Region 1 version of Stealth, ok not a great film but the DTS soundtrack is just incredible. Make sure your player can play region 1 though before you purchase.
  8. Smurkenstein
    Smurkenstein
    Sep 23, 2006
    525
    28
    +28
    Good thread...interesting POVs :thumbsup: :smashin:
  9. mistrip
    mistrip
    Aug 16, 2002
    319
    UK
    +12
    Yeah, on my all in one system (Sony DAVS800) i thought DTS sounded much better, but on my separates, Yamaha RX-V1600 and Kef 2005.2s both sound pretty similar. So now when i go back to my DAVS800 i actually think it just sounds louder in DTS (plus maybe a bit more bass). But there are technical differences aswell and the data rate is higher for DTS i think.
    Given the option i tend to use DTS though.
    What do people think of Pro Logic 2 vs DTS Neo6?
  10. sunnyb4u
    sunnyb4u
    i prefere dts neo since i use it on ym pc sound card the xfi elite pro for music it sounds brill
  11. IanW1977
    IanW1977
    Dec 30, 2002
    4,580
    West Midlands
    +484
    Snakes on a plane on the 360 through DD tonight sounded rubbish, 20 mins into the film i found out the menu had DTS and it is so much better - didn't even know the 360 could play DTS
  12. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,701
    Woking
    +235
    DTS uses less compression and a higher bitrate than does Dolby Digital so the resulting sound is slightly closer to the original master. It has better dynamics, seperation and range and is certainly not just 'louder'.
    If this is the case, then the new HD audio formats such as Dolby Digital TrueHD and DTS-HD Master Audio uses next to no compression at all so should be deafening!!! :rolleyes:
  13. Peter Galbavy
    Peter Galbavy
    This is a can of worms, isn't it. I agree with the sentiments in this thread re DTS vs. DD in general, but on many films it is hard to tell much difference - it needs a decent audio mix to start with. The old "turn it up a bit" for DD works most of the time - it's simply the larger dynamic range of DTS and viewers tend to want more loud than soft, so skewing opinions.
    Back to the Region 1 for DTS thing; You then trade off the 576 lines of PAL for the 480 of NTSC. My favorite compromise is to look for Australian PAL discs which tend to have more DTS as they don't have the same requirements for large sets of languages. As am example, I just got the Region 4 "special" edition of Event Horizon which is PAL (576 lines of video) with a DTS sound track (but not yet had time to watch!).
    So - your trade off is audio against video. We all, of course, want both to be best...
  14. Mr. Nice
    Mr. Nice
    Oct 10, 2006
    84
    +9
    It's actually a reference to the fact that DD has the dialog norm metadata whereas DTS doesn't, which does have the effect that if they are encoded from identical masters, and the dialog norm parameter has been sensibly set, then the DTS will sound louder then the DD at the same nominal volume level.
  15. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,701
    Woking
    +235
    I did say "not just louder". I agree that DTS is usually louder than DD at any given volume setting, but you can have a small radio set 'louder' than a 1000 watt amp but does it sound better? Not likely. 'Louder' is over-simplifying the difference a good DTS soundtrack can have over its DD equivalent. Stearing of effects is better, dynamics is better (not just volume, but the weight behind that volume) seperation is better with DTS and of course bass depth.
    Like I said, are you claiming that the latest HD audio formats are just 'louder' than what we have now?
    Thought not!
  16. dor146
    dor146
    I think it depends on the DVD source. I wasn't able to tell the difference with the Bourne Identity. Probably the same mix.
    But with Infernal Affairs there was a greater dynamic range. The DD mix was far less dramatic - I guess this is good for people using their tv speakers.
