fish99
Established Member
I'm in the market for a cheap Dolby Digital speaker set to go with a new widescreen tv I'm buying. I really can't afford a seperate receiver and speakers, plus I don't have any room under my tv for another box, so I'm looking into buying an all-in-one solution.
I'm looking mainly at speaker sets with a AC3 decoder built into the woofer.
The system I'm favouring at the moment is the Acoustic Solutions DS 1033 ( http://www.acousticsolutions.net/product.asp?ID=56 ), or maybe the Sony HT-BE1, which both fit the bill nicely.
Also the speakers are for a small to medium sized room, and will be used at modest volume levels.
So, my first question. Do Dolby Digital system also decode Pro-Logic signals? I would like to get surround sound from live football and movies on Sky Digital, but the DS1033 doesn't mention pro-logic or dolby surround decoding, only dolby digital.
Second question, is it a mistake to get a set without DTS and without Pro-Logic II? The Sony set has both, the Acoustic Solutions set has neither.
Last question, has anyone used either of these speaker sets and if so would you recommend them?
Thanks in advance for any help
Simon.
Simon.
