Dolby Digital Problem
Discussion in 'General TV Discussions Forum' started by DJSINGH, Jul 15, 2002.
  1. DJSINGH
    DJSINGH
    Hello,
    I have a philips 28PW9616 TV and I would like to experience dolby digital sound with this TV.
    I have got a PS2 which plays DVDs and has an Fibre optic output. I bought a fibre optic cable which fits into the back of the PS2 but does not fit in the "Digital Audio In" socket in the back of the TV.
    Is there some adapter that could attach to the end of my fibre optic cable so that it could fit into the "Digital Audio In" socket, enabling me to experience Dolby digital sound?
    If not could you let me know which DVD player I need and which cable I need (which will fit into the digital output of the TV) so that I may experience dolby digital sound with my TV.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    The Philips only accepts co-axial digital input, so unfortunately your PS2 can't be hooked up to the built in Dolby Decoder. There are converters available but they run into hundreds of pounds and aren't really worth it. As for the DVD player see my other post .
    Good luck!
  3. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
  4. Reefman
    Reefman
    Apr 22, 2002
    34
    11
    County Durham
  5. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    :blush: Wow! I had no idea they'd got so cheap! Might get one for me!
  6. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    I use the same adapter as shown on the Lektropacks site (mine was supplied by Hama) together with my 32PW9616 and it works great with both 44.1kHz PCM and AC-3 signals, both with the PS2 and Xbox.
    You have to make sure it comes with a power adapter though. The one I have did not, and has an unusual power input: 6V DC, >300mA, non-stabilized supply, 2.5mm (?) plug with positive inner pole. I had to buy a power adapter directly from an electronic parts supplier along with a separate adapter plug.
    Universal adapters may pose a problem as the supply should be non-stabilized or it might cause problems for the converter as power use varies during operation. The universal adapters I found were all stabilized.
    If the digital converter does not come with a power adapter, check before you go in search for an adapter to see if it has the same power input as I mentioned.
