dolby digital passthrough via SPDIF
Discussion in 'Desktop & Laptop Computers Forum' started by John_N, Feb 5, 2003.
  1. John_N
    John_N
    I've just set up my HTPC for a trial run.
    I have a sony HS10 projector linked via DVI to Radeon 9000 pro card.
    And a Philips Sonic Edge 5.1 linked via SPDIF to a Nakamichi AV amp.
    The visual side works fine and I get widescreen video OK.
    The audio side is sort of working - I am getting PCM stereo out of the card SPDIF so using the amplifier digital input I can hear all the windows sounds.
    However, when playing a DVD using winDVD, I just hear the sounds in 'stereo' (PCM audio being transmitted over the SPDIF link is stereo NOT 5.1 channels).
    I've tried enabling 'SPDIF out' on WINDVD - no joy. The sound just goes completely dead.
    Has anyone got any ideas about a player I could/should use or something I can do to make sure that I'm getting the full 5.1 channels passed through to my philips sonic edge card's SPDIF output?
    I don't have any wires connected internally in the case to the Philips 'SPDIF in' ports or anything by the way.
    John
  2. Gerbil
    Gerbil
    May 20, 2002
    269
    Newbury
    +23
    I don't use WinDVD, but i seem to remember reading something about SPDIF output only working in WinDVD if hardware acceleration is disabled.
    Have you seen here
  3. John_N
    John_N
    Hi Thanks for the ideas.
    No - didn't work. Like I said I get SPDIF digital output - it just is PCM audio which is 2 channels only. I'm not getting passthrough of the unaltered digital signal from the DVD.
  4. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    Hi John,
    What operating system are you using?
    Cheers.
    Tim.
  5. John_N
    John_N
    I'm using windows 2000.
    I got it working anyway. I used a different DVD player. I downloaded a trial version of PowerDVD and it worked fine so I bought the full version online.
    System configuration is now:
    Windows 2000
    Radeon 9000 pro - DVI output to Sony HS-10
    Philips Sonic Edge 5.1 - SPDIF to Nakamichi
    ATI Remote Wonder remote control
    Player: PowerDVD
    This seems to do everything; I now get my DVD output in full 5.1 surround and I get system sounds in PCM stereo so it means that the system is controllable totally from the couch.
    Fantastic.
    I watched a movie last night and got concerned about image quality. Turned out I was watching it in 16 bit colour by mistake.
    Upping the colours to 32 bit made a big difference. The picture is very very good.
    My only concern is that in very slow pans, I see the picture judder a bit. Is this normal? It only happens in very very slow pans.
  6. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    John,
    For the sp/dif to work in windows 2000 you need at least service pack 1 pref' 2.
    LMK if it works.
    Tim
