Dolby Digital or DTS
Discussion in 'Blu-ray & DVD Players & Recorders' started by nimni, May 27, 2004.
  1. nimni
    nimni
    I am new to Dolby Digital and wander is there any deferens between Dolby Digital and DTS sound formats
  2. theroohster
    theroohster
    DTS uses less data compression that Dolby Digital, and should in theory sound better - in most cases it does!
    More DVDs are starting to carry both DD and DTS soundtracks, so its well worth having.
  3. scrapbook
    scrapbook
    Jan 12, 2002
    7,426
    +552
    I tend to use DTS when I have the choice of both, but in reality I think you have to have a very HOT system and accurate hearing to tell the difference!
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    there are (as mentioned) technical differences. The one which I find most important is that dts is actually a tad louder for a given volume setting, all my friends prefer this. My own preference depends on the disc and I dont think that either really provides a noticeably superior sound to the other. For a novice I dont think they would notice if the amp never went to dts. Even being a bit mad on this hobby, a DD5.1 track is all i need to keep me happy.
    ad
  5. kazzup
    kazzup
    Dec 22, 2003
    42
    West Yorkshire
    If given the option I always listen in DTS, it seems to have a more dynamic sound. But I've also listened to a friends system and couldn't tell the difference between the two. Maybe it comes down to interaction of all the components.
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the dynamic sound is often attributed to the raised levels.... I strongly suspect that people would have far less dts perference if the levels were matched to those of DD
    ad
  7. kazzup
    kazzup
    Dec 22, 2003
    42
    West Yorkshire
    I dont know about raised levels, but i'm only comparing with the volume level that I listen to. Always at -35db be it DD or DTS.
  8. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    what i mean is for a given amplifier setting, dts will be louder. So unless you actually increase the volue when listening to DD, you wont be listening at the same spl
    ad
