Dolby Digital from my Sky+ box?
Discussion in 'Sky Digital TV Forum' started by Kasperoff, Apr 18, 2005.
  1. Kasperoff
    Kasperoff
    What do I need to achieve this.
    I have a Denon 3805 Amp and until the weekend had the two connected via a phono interconnect. I was under the impression if I got hold of a optical digital interconnect I would be able to run with Dolby Digital. However, I did this at the weekend, and I still can't select Dolby Digital on my Amp when watching Sky.
    Is there something I've missed? Have I even got the correct cable? The only other option seems to be digital coax (as well as the phono socket).
    Ta.
  2. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    I don't have SKY+ but I'm fairly certain that they only broadcast DD5.1 on some of the movies. You won't get it for normal TV channels. There's some indication in the EPG if they broadcast the programme in DD5.1 I believe.
  3. John
    John
    Dec 13, 2002
    10,998
    +2,676
    Enable DD out in the Sound Settings menu under Services .As danluton said , DD is only broadcast on Movies 1 2 & 3 and occasionally the Disney channel
    atb
    JS
  4. Kasperoff
    Kasperoff
    Ah. I need to fiddle with the Sky menu eh!?
    Thanks guys. I'll have a look tonight.
    I have Matrix Revolutions on my HD. That will surely will be in DD?
    Ta :clap:
  5. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Not necessarily as they don't always broadcast DD even if it's available.
    John
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    With most amps you don't select DD - it is selected automatically when a DD bitstream is detected.
  7. chillo
    chillo
    Sep 15, 2004
    732
    Northern Monkey!
    +25
    i have a 3802 and have the same probs, i haven't had chance to sort it yet but you need to go into the denon amp menu and enable it from there
