Dolby Digital / DTS via analogue outputs?
Discussion in 'Desktop & Laptop Computers Forum' started by cbemoore, May 16, 2005.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    Until now, I've been using the SPDIF output from my HTPC into my Rotel processor, and onwards into my Mackie active speakers.
    I've now decided to sell the processor, and plug my speakers directly into the PC. So the PC will be acting as a processor.
    I've just bought an M-Audio Revolution 7.1 soundcard, which does Circle Surround II processing for 2-channel inputs (eg TV and music). But I'm not sure what happens if I input DD/DTS when playing DVDs.
    As far as I can tell, the audio should be handled by the DVD decoder software (I'm using the NVidia decoders). But the NVidia documentation seems to say that is doesn't decode DD and DTS - instead, it just passes the digital stream to the SPDIF output.
    Is there any DVD decoding software out there that decodes DD and DTS, and sends the decoded signals to the analogue outputs on my sound card? Or does the NVidia decoder do this already?
    Chris
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    Nvidia decoders decode DD & DTS as do PowerDVD & WinDVD
  3. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Theatertek with the advanced audio packs works a treat (Only does 5.1 however)
    RON
  4. Embarker
    Embarker
    Apr 19, 2004
    1,676
    Garden of England
    +70
    theatertek II with an rme card is neck and neck with a MC1 via balanced outs :thumbsup:
  5. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Media Player Classic decodes DTS too :) useful when you have avis with a DTS track!
  6. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    Thanks for the advice, guys. But I'm still a bit confused.....
    The Revo 7.1 control panel includes full bass management, including speaker volume levels, size, distance, crossover frequency etc. It also contains Circle Surround settings for converting 2ch stereo into 5.1 surround.
    However, the NVidia control panel also contain individual channel volume, speaker delay and so on.
    When I play a DVD, will the NVidia decoders use their own bass management settings and completely bypass the Revo settings? Or will the two settings get overlayed onto each other?
    Chris
  7. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    I've just been reading the NVidia website, which states quite clearly that the NVidia decoder does NOT support DD or DTS via the analogue outputs!
    See here and here for details.
    Instead, the 5.1 soundtrack is downmixed to 2 channels.
    So it looks like I need to find another decoder!
    Chris
  8. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    If you get theatertek and the advanced audio pack you can deocde DD/DTS on your PC and pass it to the analogue outs of your revo. I do this now. It works. TT has bass management so you can use that or the one on the maudio revo's setup screen.
    Not really sure about the quotes from Nvidia's site but trust me TT + nvidia codecs + Maudio Revo = multichannel analogue out works just fine.:)
    HTH
    Owain
