Dolby Atmos speakers downward firing
adamrs6
Hi guys
I have a budget of £300-£400 and would like to buy some decent front height speakers that are dolby atmos.
They would need to be downward firing.
My set up is:
Arcam avr 550
B&W DM 603 S3 L and R
B&W LCR 60 S3
B&W DM 601 S3 rear surrounds
SVS Subwoofer.
Would like to hear peoples personal experience with any recommended speakers.
Also where on the front wall would I be best to place them?
Many thanks
Jester1066
A pair of Dali Alteco C1's mounted on the wall at ceiling height and in line (directly above the front L&R speakers:
I have these speakers and they work really well in this configuration. They have simple keyhole style mounts, so 2x screws for each speaker.
gibbsy
There is no need to get the special Atmos speakers. Any speaker angled towards the MLP will be more than sufficient. The main advantage of those Atmos speakers is that they already have a firing angle built in as well as having keyhole fittings for ease of placement.
Your position should be in line with the front left and right.
Gasp3621
Hi guys
My set up is:
Arcam avr 550
B&W LCR 60 S3
SVS Subwoofer.
Many thanks
You can also mount them slightly wider than mains if it looks better, but not too close to side walls (1feet min) as the fire forward when mounted with the two screws (keyholes at rear). Below is few good choices all available in black too, but if you have white walls then i would keep the speakers white and run the wires near the ceiling with white trunking for best "blending".
adamrs6
Going for the Dali Alteco C1.
Just wondering, if anyone can recommend wall mounts for these so I can stick them to the wall and angle them to the listening position?
Jester1066
I got these to hang my 4 C1's in the same way you want to
(They also do a 2 pack version):
deleyCON 4x Universal Speaker Wall Mounts Loudspeaker Wall Mountings Tilt + Swivel up to 10 Kg Load Weight Ceiling Mounting + Wall Fitting - Black Amazon product
They come with multiple fixing options etc. Really good quality imo 👍🏼
Gasp3621
You don´t need to angle them, Dali doesn´t recommend angling for ANY of their speakers cause they already have wide dispersion and can become overly bright if angled. However if for some reason you still want to do that, then see the attachment and the thread..
Jester1066
The brackets used in the picture @Gasp3621 shared a virtually identical to the ones I linked to above btw
Jester1066
adamrs6
In the OP, the picture i put up of my set up. Would you say the floorstanders are okay where they are or should they be wider. I have my subs to either put on the outside of the fronts or inside closer to the cabinet?
Gasp3621
There is pros and cons either way. If you spread them more apart and they go almost in corner, make sure they are pushed good amount forward and try differnt toe in (angling) toward listeners. Run your receives setup again if you move the position of speakers and sub. Only way to know for sure is to try it out and give it few weeks.
Personally i would bring the center channel at the front edge of the av-unit or at least buy or build yourself a table stands for them to raise them up as you have space below tv still, why not use it all to get the speech locked higher where your ears (and main speaker tweeters) are when seated.
