Quantcast
Question Dolby Atmos on Disney+
Lhasadreams
I stream using at Apple TV (4K) to an Arcam AVR390 configured as a 5.1.4 system.
Today I added Disney+ to the Apple TV.
All of the Star Wars movies say that they are in Dolby Atmos, but my AVR reports Dolby Surround when playing them. I can stream Apple Dolby Atmos movies and the AVR detects the Atmos fine.
I tried some other Disney+ movies and found that the Lion King and Toy Story 4 actually stream in Atmos.
Has anyone else managed to get the Star Wars movies to stream in Atmos?
Adrian
jwsg
As you'll see from the other Disney+ threads esp. Disney plus - No atmos from apple tv 4k this is common. All the streaming services have switched to lower bit-rates for audio and video which for D+ means the 5.1 stream without Atmos. The film info shows Atmos if your device would have been able to handle it.
Lhasadreams
Ok thanks.
Strange that a couple of the movies still stream with Atmos though, I would of expected the bit rate throttling to be across everything.
Adrian
jwsg
Ok thanks.
Adrian
it would be useful to know which ones as I've had no luck so far. I think its possible it works by having a set of versions of each film with different bit-rates and configurations that the app normally chooses between based on your line conditions and device - rather than them being able to vary bit-rate on the fly. The streaming companies would then have simply removed the top tier versions - but maybe missed some.
Lhasadreams
The Lion King and Toy Story 4 did but have since been reduced to 5.1 surround.
Part 2 of Mandalorian played with Atmos tonight, but not part 1.
pavloPL
I think Disney downgrading sound for Europe, they don't for US however so I use Smart DNS to trick it is from US and having Atmos on all Mandalorian episodes and Star Wars so far.
Similar threads
