Telumehtar
Established Member
To be honest, the thought of making holes in my ceiling and routing the wires was quite daunting. I wished there was some sort of tutorial to let me know what I was in for. But most such information I found was for Americans with big houses and things like ceiling tiles.
So I just got on with it and it was easier than I thought.
Here are pictures showing the progress with a description of what I did under each one:
Dolby Atmos ceiling speakers installation
The speakers are KEF Ci160QR that I got on eBay for a bit less than retail price.
This is the tool I used to make the 196mm diameter holes in the ceiling. Well worth it as it made the hole cutting easy and relatively mess-free: Armeg AHC40-200 40-200mm Adjustable Hole Cutter: Amazon.co.uk: DIY & Tools
I was somewhat lucky because previous re-wiring and central heating installation had left some floorboards cut short and screwed down instead of nailed, and there were holes in the joists I could use to run wires through. Getting the holes in the right place was a matter of measuring to find where in the room above they would be, pulling the nearest floorboard, putting speaker down there to make sure it fit and avoided pipes, then making a small pilot hole from above. The pictures show some more details.
How does it sound? Pretty good to my ear, though the only other Atmos I've heard was at the Olympic Studios cinema in Barnes. I have no idea if Atmos bounce-sound-off-the-ceiling would have worked but intuitively I preferred the idea of real speakers. These KEFs seem good because they are supposed to sound good well off-axis, and I might get LS-50s for the front 3 speakers at some point so things will match to an extent, though I'm not sure it matters much.
My rears are higher than Dolby say they should be for Atmos, but I don't think it's a big deal.
Ceiling speakers are in line with where my feet go and just to the left and right of the sofa.
I did YPAO and found it good but all a bit subtle, so then I added a couple of dBs to the level of the overheads and it is now probably a bit too in-your-face, if impressive. I'm sure I will be doing a lot more tweaking.
But all in all I'm pleased with how well the physical installation went. Please ask questions or feel free to tell me I did it all wrong!
Edit: this is the wire I used. But [edit 2] don't use this because it is not correct: AWG 13 - 2x2,5mm² - 30m Role | DCSk HiFi Copper Loud: Amazon.co.uk: Electronics
Use this instead: Mutec-Cable -Speaker Wire 2 x 2.5mm² 50M CL2 Rated UL: Amazon.co.uk: Electronics which has CL2 rating for fire safety (fumes and flammability).
You want proper copper and thick enough wire for the length of the run but not too thick as it is harder to route.
Also it is important to use a fire hood over the speakers as the a fire will melt the speakers and allow smoke through the hole. These are readily available. I am going to try these: Fisual FH-300 Universal Fire Hood For Ceiling Speakers - In Ceiling Speakers - AudioVisual Online - Home Cinema and Hifi Specialists
