Does Wavebird work through solid items?
Discussion in 'Nintendo Forums' started by kwangomango, Sep 4, 2003.
  1. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Gonna have my GC inside my Loewe Mimo cabinet. The door is about 1/2 inch thick plastic. Is the Wavebird signal likely to penetrate this ok?
    The back of the cabinet is open, so if it doesn't work through the door the should it be ok bouncing off the wall and into the open back?
    Many thanks.
  2. pingtuk
    pingtuk
    Feb 5, 2003
    76
    It should work fine through solid objects as long as its not lead or something. I've even tested it while I was downstairs and the gamecube was upstairs and it worked fine, pity I couldn't see what was going on though. ;)
  3. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Thanks. Thought it would be fine as it's a radio signal, but i heard that it only had about a 20ft reach in free space so thought i'd double check.
    Do you know if there is anywhere cheaper than £29.99 in p+p?
    All videogame related sites are blocked at work including price-checker:(
    Ta
  4. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Mine worked perfectly fine when I tested this:
    Through the floorboards of my room, through 3 seperate walls, a patio door and with me at the far end of a 20ft garden. Total distance: maybe 45ft, 3 brick walls and a double-glazed patio door.
    So I think a 1/2" plastic door will be ok :D
  5. shaq365
    shaq365
    Sep 4, 2003
    62
    Aberdeenshire
    +3
    You can get a Wavebird for less than £25 from DVDBoxOffice.com.
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    I can play my cube via a wavebird from outside my flat (it would work but I can't see my telly from there!)
