Does VGA to component cable produce pixel for pixel on HDTVs ?
Discussion in 'LCD & LED LCD TVs Forum' started by lambert, Dec 29, 2006.
Tags:
  1. lambert
    lambert
    Dec 28, 2006
    54
    Hi all
    This topic kind of stems from my last post.
    Basically I have a hdtv with no dvi or vga inputs. Im trying to get my pc to run on the tv pixel for pixel. The Tvs resolution is 1366 x 768,
    Currently Im using DVI to HDMI but this wont let you produce pixel for pixel resolution but I keep reading that a VGA connection lets you do it pretty easily ( via powerstrip )
    Anyway Im just wondering if anyone else has tried VGA to component cables on a hdtv and does it work ?? Ive used component cables on xbox and the pixture is awsome !!!
    Any advice would be great,
    Cheers guys :eek:)
    Will
  2. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    I'm sorry but there’s no way to obtain 1:1 pixel mapping via component. However, you can enter the service menu and manually adjust the screen to compensate the overscan.
  3. lambert
    lambert
    Dec 28, 2006
    54
    ok, well am i fighting a battle I cant win if im after pixel for pixel but havent got a vga port on my tv ?
  4. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    yes you are
  5. cheesegoduk
    cheesegoduk
    Dec 12, 2006
    46
    9
    Try a DVI to HDMI cable if you can get one. Its what I use on my KDL-W402000 to get 1:1 Mapping @ 1080p
