Does TY-KW42PR1 fit Viera PE30?
Discussion in 'Plasma TVs' started by sabujo, Aug 5, 2004.
  1. sabujo
    sabujo
    Just in case someone knows the answer, I thought I should ask. Never hurts :D
    If it helps, this is the tiltable wall mount support for the pw6
  2. sabujo
    sabujo
    sorry to nag you about this, guys, but my viera is almost coming and i still have nothing to hold it straight. If in panic, i'll buy a Vivanco tiltable wall mount and hope it fits. Can anyone at least tell me if the vieras are atached to the wall mounts using screws or is it something else?
    thanks
