Does Toshiba 340E support +RW?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Geoff, Jan 2, 2005.
  1. Geoff
    Geoff
    Does Toshiba 340E support +RW? I've found a site which suggests it does and several which mention only -R and -RW.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    If you have a look Here you will see that it can play back a DVD+R disk, but not all of them. Therefore I would assume it will be down to trial & error to find the disks that will work. By the looks of it all DVD-R(W) and DVD+RW disks will work fine though so you may be better off sticking to creating DVD-R.
    Mark.
  3. nictry
    nictry
    Apr 28, 2002
    5,479
    Kent
    +601
    I can only confirm -R and -RW do work fine, even before any finalisation of the discs which I must admit impressed me! Sorry can't help with +RW though?
