Does this system look ok ?
Discussion in 'Plasma TVs' started by Pogue, Mar 21, 2005.
  1. Pogue
    Pogue
    Mar 16, 2005
    15
    Does this look ok to you guys ?
    Panny PWD7 + Component board
    Yamaha RXV650 Receiver/amp
    Panny DMRE 85H DVD/R HD
    Canton CD1 plus CD50 rear centre
    Sky digibox
    Would this all work ok?
    Does the RXV 650 have prog scan thru component to the screen ?
    Any help appreciated as I want to order today if possible :clap:
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    you can just plug sky into the dvdr and the dvdr via component to the pwd7...no need to put video through amp. cd1 in my experience is excellent choice! you may find screen does prog scan better than dvd anyway....
  3. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    My only comment would be to put the CD50 as the front center and the CD1 center as the rear one... Doesn't affect your order though :)
