Enjoysmoviesandgames
My mate was kind enough to let me borrow his 360 to check my TV was HD.
I connected it all via the component leads and set the switch on the lead to HD.
I then went to the 360 tv settings bit and changed it from 480p to 720p and and 1080i and it displayed it ok. I think at 720p the display sewtting was 1200x720.
I played a couple of games and it all worked ok in 720p.
Does this mean my TV is HD then and is all working fine,
The pic was better at 720p than 480 and the screen res was also higher.
Have I failed to do something or is my plasma HD as I will buy a 360 if this is the case.
