Does this look good?
Discussion in 'Projectors, Screens & Video Processors' started by 9761, May 29, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    Need a new TV in my bedroom so I just want some opinions.
    Im going to get the
    Samsung WS28A116DU 100Hz and freeview built in
    and
    Panasonic SC-HT870 Home Cinema Kit (1000 Watts RMS :eek: )
    Im only 16 so I do want to disturb the Neighbours and on a Tight Budget of around £550 and under :p
    Thanks (not sure what Forum area to put this in)
  2. crispybig
    crispybig
    Sep 28, 2004
    273
    +6
    Hi 9761 :)
    I'm sure you will getter a better response if you post this question in the "Televisions....." and/or "All-in-0ne systems" forums. This forum is all about CRT Projectors, the big three-eyed monsters.
    Perhaps you'll be back here one day once you've learned about the rest and decided you want the best! :smashin:
    [nostalgia]Ahhh - it takes me back to wen I wur a lad. You're spoiled for choice these days. The only coloured pictures I had were in my crayoning book (I was a late developer :D ).[/nostalgia]
    Good luck with you search - I hope you find something that meets your needs at an affordable price.
