Does this exist?
Discussion in 'Cables & Switches' started by vileda, Dec 2, 2004.
  1. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    Hi, :hiya:
    I'm still debating which plasma to get and am looking at the connections on offer.
    Is there such a thing as a Component (3 rca) to VGA (or DVI) converter/cable. If so does anyone have a link.
    Vileda
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can get a cheap VGA cable by getting a cable from ebuyer.com - a "Belkin Pro Series High Performance 5 BNC Monitor Cable 1.8m" for just over £10 + VAT (Quickfind Code: 28640). This has 5 BNC plugs for the component outputs, usually for connection to expensive component VGA screens. You can either cut the BNC's off and solder some RCA phono jacks, or buy some BNC<>phono adaptors from Maplin Electronics.
    Someone said that you can get the cables cheap from Maplin Electronics too, but I've not seen them.
  3. vileda
    vileda
    Oct 15, 2004
    401
    Thanks Nick
    Is`this not a RGBHV > VGA cable? I was hoping for component (3 cable sync on Green) to VGA converter if such a thing exists.
    Alternatively this with a Component to RGBHV converter could work i suppose.
  4. boardwalk
    boardwalk
    Apr 29, 2004
    Hi, :hiya:
    try this link Best Stuff they have a couple of different makes on here. I have just purchased the 18.99 lead and it works perfecly. :smashin:
    Dave.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Component is Y, Pb, Pr - what you want is RGsB to VGA :)
  6. boardwalk
    boardwalk
    Apr 29, 2004
    One thing I forgot to mention is that you must ensure the screen you buy can set VGA input to component to use this cable.
    Dave.
