does the toshiba D-R1 play dvd-rw discs
Discussion in 'Movie Forum' started by brian.stewart70, Oct 28, 2004.
  1. brian.stewart70
    brian.stewart70
    I have just bought the Toshiba D-R1 DVD player, it plays dvd-ram discs and dvd-r discs perfectly, but I cannot record using dvd-rw discs. Can anyone recommend a brand of dvd-rw disc that records.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,117
    2
    In a secret location with Jennifer Lawrence
    +10,006
    What brand are you currently trying? This machine should do all the formats you listed.
  3. brian.stewart70
    brian.stewart70
    I have used "datasafe" 2xspeed dvd-rw discs, I have no problem recording with the dvd-r discs, but I cannot record with the dvd-rw discs for some strange reason
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    The DR1 is very fussy with DVD-RW media: try some good quality, branded disks. Scrathproof TDK seem quite popular on the DVD Recorders forum.
