does the Tosh XS32 have rgb in and out
Discussion in 'Blu-ray & DVD Players & Recorders' started by get1a2get1a2, Aug 9, 2004.
  1. get1a2get1a2
    get1a2get1a2
  2. kdp99
    kdp99
    Mar 29, 2001
    209
    Southampton,Hants,UK
    +24
    Yes !!
  3. loreweb
    loreweb
    yes. but I don't succeed in viewing the rgb program (entering in rgb via scart) on my tv. if I set the av2 input in rgb mode I see the monitor black
    someone can help me??
    thanks
    loreweb
  4. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    Works for me. Maybe check your AV1 out settings on the Tosh?
  5. loreweb
    loreweb
    How have I to set the 2 scart connection? If I set AV1 "rgb out" and AV2 "rgb in" I see black monitor....
    thanks
    loreweb
  6. monocrider
    monocrider
    Works fine for me too.
    What is your RGB source ? Is it definately sending an RGB signal to the X32 ? If it's a Sky box, don't forget that if you press TV on the Sky remote, it switches off the RGB output until the next time you press the SKY button.
    Regards,
    John
  7. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    and either the machine needs to be on OR you have to press sat mon.
  8. loreweb
    loreweb
    yes, is a skybox
    INCREDIBLE! Is this the problem?? only I have to push the sky button?? later I'll try, thanks!!!
    excuse me, CLH, what machine nedds to be on?
    thanks. ciao
    lore
  9. loreweb
    loreweb
    Last question: to see the SAT through AV2 in RGB mode, I need to push the sat button on the remote? (SAT MONI or SAT CONT, I don't remember the name). Because without push it, I see the monitor black, also pushing the SKY button on the skyremote
    thanks, ciao
    loreweb
  10. loreweb
    loreweb
    Can someone definitively explain to me if I have to set the tosh with SATMON to see SKY in AV2 IN and then AV1 OUT in RGB?
    If I don't set SATMON I see the monitor black, but I'm not sure that pushing the SATMON button the signal out is really RGB...
    Can someone help me please?
    thanks. ciao
    loreweb
  11. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Turn on Sky with RGB output.
    Scart out of Sky into AV2 on Tosh, AV1 scart out to TV.
    Press satmon.
    RGB passes through.
    It is definitely RGB
  12. loreweb
    loreweb
    many thanks. it's everything allright now
    ciao
    loreweb
  13. loreweb
    loreweb
    Hi, I've another problem:
    when I try to record SKY via AV2 in RGB mode the result is all black (again!!)
    I've tried with and without pushing SATMON, but it's the same
    What's the problem? When I want to record SKY I have to put S-VIDEO mode? It's impossible to record in RGB mode?
    Thanks, ciao
    loreweb
