Does the sub work during normal stereo?
ddaddy
I am thinking of buying a sub/sat speaker system to run through my sherwood amp, but read somewhere that i should check to see if the amp uses the sub during normal stereo music output. Or is the sub only used during 5.1?
cheers
N
naturally
I am no expert, but I think that this is dependant on your reciever.
On my Denon reciever for instance, I have a Stereo and Direct modes. The Stereo mode uses the cross-over to activate the Sub, and the Direct mode sends all to the two front speakers.
petrolhead
On my denon 3802 even in direct mode the sub is still used
James45
don't use source direct on your amp if you have satellites. Many satellites won't take to kindly to the full range signal sent by source direct... stick to the stereo setting and this will preserve your speaker "small" settings.
LDR
My sub works on my Denon 2802 when playing CD's & MD's etc through Direct mode.
And jolly fine sounding it is too !! :D
Jase
You can turn the sub off in Direct Mode if you want to, just go into the individual channel level settings for that mode and turn the SW channel down to -12 and then OFF.
Denon give you this option if you have floorstanders or don´t want to use the sub for any reason.
Direct mode sends full range signals to the front channels regardless of speaker settings in the main set up menu.
petrolhead
Hm
Will try that Jase.
Whats the weather like there ?
Jase
Hm
Will try that Jase.
Blue Sky & sun (well not at the moment because its night time:D ). Cold though................ 15 degrees:p :D
ddaddy
Just thought i'd come back and answer my own question for future reference for people.
The speakers i was interested in, where the mission FS1 set.
I got them delivered today, and in the manual it says they have a built in crossover, so no need to even connect the sub up if you dont want to and it still works.
Obviously, i'll connect the sub for 5.1, but for stereo it'll work either way.
Ian J
The FS1 speakers are not full range and will probably sound terrible without the sub connected as there will be no lower mid range or bass.
ddaddy
even with the sub not connected to the sub output on your amp, the sub still works. Theres a built in crossover that i assume sends the bass to the sub.
