Does the Pioneer 868 suffer from CUE?
Discussion in 'Blu-ray & DVD Players & Recorders' started by MJeeves, Sep 23, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks.
  2. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Anyone know?
  3. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Might be able to anser, as soon as I know what CUE stands for...
    Barend
  4. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
  5. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Yes, but not as severe as past models as only plays up on a few discs. and i mean a few
  6. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks Gandley!
    Do you know what discs? Also, is there a firmware update on the 868 - what is the latest firmware (how do you check?)
    Thanks buddy! :thumbsup:
  7. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    if your buying a new unit now it will be upto date.
    think there has only been 2 releases of firmware(maybe 1) since release.
    Cant remember what discs, but none of my favs were effected.
  8. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks Bud! :thumbsup:
  9. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    My firmware says : Region 2 / VER: 1.406
    The unit was manufactured in Mar 2004. Will it be one of the older units that has HDMi quirks and the Chroma Upsampling Error (C.U.E.)?
  10. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Anyone?
  11. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,105
    Southampton
    +260
    M.J - Stupid question,but how do you go about checking what firmware version you have.Mine was made in May 04 - I will report back what version I have when I know how to check!
    Jerry
  12. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,105
    Southampton
    +260
    Just sussed it (doing a search helped!!!! DOH!) - Mine says
    "Region 1 / VER: 1.506(16)/ AV1: 2.0/2.8"
    One thing that startled me,was the region 1 tag - tried a experiment,and played a region 2 disc - it then stated region 2.
    So it appears the region tag displays the region of the last disc you played - obviously i'd been watching a region 1 on the last play.
    I'd only remote flashed my player last Friday,using my Simpad & RCII,to make it multi region,as it was region 2 locked - so my heart stopped,as it the occurred to me,I hadn't actually tried a region 2 disc up until checking my version number on hour ago!!!!
    All worked wonderfully.... :)
  13. V5-APS
    V5-APS
    May 7, 2001
    681
    London
    +15
    Moviebuff....can this method be used to upgrade the firmware form an earlier revision ??
  14. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,105
    Southampton
    +260
    As far as I'm aware,you have to have the firmware flashed by a service agent.My player already had the latest firmware - for me,it was just a case of removing the Region lock by using a Pronto type remote.
