Does the Pioneer 434/504 have a media slot?
Discussion in 'Plasma TVs Forum' started by AngryofMayfair, Aug 14, 2004.
  1. AngryofMayfair
    AngryofMayfair
    I see some reviews where the media box has a slot for viewing jpg pics and yet the 434HDP I have seen don't have this slot - confusing...
  2. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    The ones I've seen have. It's behind the pull down front flap on the media box. It takes a PC adapter card which you can fit in various media cards.
  3. AngryofMayfair
    AngryofMayfair
    Thanks for that - bummer - it looks like us Aussies have been short changed again there's no card slot under our flip down panel just a component and VGA input... :-(
    Anyway I think I'm going for an MXE1 - it seems to be the better otpion - more connections and setup options and it's a bit cheaper too...
