does the Panasonic panasonic TX-47AS650B have an analogue tuner??
Discussion in 'Panasonic TVs Forum' started by gbmitie, Jul 7, 2015.
  1. gbmitie
    gbmitie
    Apr 25, 2001
    1,193
    49
    republic of ireland now
    +71
    A friend in Ireland has bought this TV and it replaces an old CRT TV but there is a problem. They used to have Sky tv piped via coax to old tv and used ch42 and used a magic eye. However, with the new Panasonic they cant tune in the analogue channel as they cant find the analogue Tuner!! The manual says use the auto setup and then select analogue but that option never appears. They have tried a few times.
    The spec says it has digital and analogue but its either well hidden or does not exist.
    Badge on back says Panasonic TX-47AS650B.
    I am stumped in that I cant find analogue setting. It was set up by shop so I dont know if this tv gives 2 options ie either UK or Ireland.
  2. BigD18t
    BigD18t
    Sep 5, 2012
    7,420
    3
    Somerset
    +3,635
    Yes it should have, normally pressing the Tv Button will switch between tuners.
    Make sure I'm The setup menu under display settings then input labels that analogue isn't skipped as it won't show then.
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,193
    49
    +71
    Thank you, I will check that out. That is probably what happened.
  4. silversurfer24v
    silversurfer24v
    Jan 15, 2006
    754
    3
    28
    lincs
    +81
    In set up due then dvb tuning due they have the option to add another tv signal as this is where analogue tuning is on my 802b
  5. gbmitie
    gbmitie
    Apr 25, 2001
    1,193
    49
    +71
    OK An update. Its just a case of pressing the right button!! So to get the analogue tuner you just press TV and then menu etc. Then to get back to DVB tuner press tv again!! Its that easy when you know how. Also under display settings you can actually hide the analogue tuner which is nifty but if one did not know they would assume TV had no analogue tuner.
    thanks for replies.
