Does the Panasonic e30 record in NTSC
Discussion in 'Blu-ray & DVD Players & Recorders' started by jools 2001, Dec 21, 2002.
  1. jools 2001
    jools 2001
    Just wondering if anybody knows is it possible
    to record a ntsc signal thru the E30.
    I have a multi sat setup,and when i record a ntsc programme,
    it appears in black and white.
    the sat reciever (echostar dsb 2110) has a built in ntsc decoder
    which will allow me to watch it on my toshiba widescreen tv in colour.
    Do i need to change a setting on thd panny dvd,or am i destined
    to watch any ntsc recordings in good old black and white:(
    I have freeview fed into av1,and my echostar fed into av2.
    i have tried swopping the av connections over with each other,
    but its still recording the ntsc in black and white
    any help/advice greatly appreciated
    jools 2001 ;)
  2. Duvel
    Duvel
    Feb 15, 2002
    Northampton
    +3
    The E30 does record NTSC (and a fine job it does too);) .
    You just need to change from Pal to NTSC in the tv dispaly settings on the E30. only thing it won't do is mix a NTSC recording on the same disc as a Pal recording.
  3. jools 2001
    jools 2001
    thanks m8
    found the settings;)
    have you got any tips for the panny?
  4. Duvel
    Duvel
    Feb 15, 2002
    Northampton
    +3
    One thing I have found is that timer recording is not always reliable:( but i believe this to be a media problem as when ever I have used a RAM disc for timer recordings it always works. The problem only seems to appear when using DVD-R. On a few occassions I have missed programs set to record through the night when using DVD-R. I really do think this is down to individual media though as it has happened with Traxdata, Datasafe Classic and FWS discs. It can be a bit annoying as it is very intermitant but now I either use Ram discs or start the recording manually for anything important I want to record. Other users have reported this prob too and the consensus is it's a media problem. I think the only way to avoid this particular prob is get expensive or genuine panasonic DVD-R:(
    The funny thing is when starting the recording manually I haven't had one failure yet with DVD-R and I recorded a fair number of disc now.
    For progs you just want to watch then delete DVD Ram is really very good and the video chasing mode more useful than I thought it would be.
  5. jools 2001
    jools 2001
    thanks duvel,
    just trying to get me head around
    the panny manual at the moment;)
    are there any dedicated forums for the e30
    that you know of?
    thanks
    jools 2001:D
