Does the MS hi def kit inc the component cables
Discussion in 'Nintendo Forums' started by Dextur, Sep 16, 2004.
  1. Dextur
    Dextur
    Aug 30, 2004
    10,189
    +1,749
    Guys
    Does the official Microsoft High def kit actually include the component cables?
    I am looking here at where I bought it from
    http://www.lik-sang.com/image.php?category=83&products_id=1742&img=xbox-high_def_av
    And I can clearly see the component sockets, but the cables included don't look like component cables, Normally they tend to be Red, green and blue.
    On another issue , on this image
    http://www.mx2.co.uk/acatalog/XBOXHDTV.html
    I can see it includes an optical out which is nice (would have preferred coaxial) but does anybody know if they include a cheapy optical in the lip sang kit.
    Just trying to workout what else I need to order in advance.
    pps how long did it take your ling-sank delivery to the UK?
    Anyone with the lik sang one confirm for me
  2. John
    John
    Dec 13, 2002
    10,978
    +2,663
    yep , came with cables .Not very long iirc .del took about a week
  3. Dextur
    Dextur
    Aug 30, 2004
    10,189
    +1,749
    coolthanks , component and optical included?
    It's just those cables in the image do not look like component cables, but if you say it's got em, that will do me..
    I ordered about 8 days ago now I think.
    Interested to see what the upgrade in quality will look like that's for sure.
  4. M0T
    M0T
    Jan 27, 2002
    141
    +5
    My hi def pack came with a set of component cables that are 1.5m long.
    The reason you see the red and white audio cables is because the cable that comes with it is a 5 cable loom, 2 audio cables and 3 component cables.
    It did not come with an optical cable.
  5. Dextur
    Dextur
    Aug 30, 2004
    10,189
    +1,749
    ahh ok, thanks very much for that most appreciated. I think 1.5 m from my xbox to amp would be just enough, ( i run component via my Denon avr3801 and then out to the tv)
    I will go order an optical now for when the kit turns up.
