Does the MAranzt SR4300 Have SPDIF Connections?
Discussion in 'AV Receivers & Amplifiers' started by Nixon, Jul 31, 2003.
  1. Nixon
    Nixon
    IT says it all in the title.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    According to www.avland.co.uk the Marantz SR 4300 has 2 co-axial and 2 optical inputs.
    Steve
  3. Nixon
    Nixon
    So this means that it does?
  4. adc2000974
    adc2000974
    wow 2 coax, thats plentiful and generous
  5. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi All,
    Dutch is right, there are 2 optical and 2 coaxial on this amp.
    After first trying out optical yeah sounded great, but since going over to a coax connection it even better !! ;)
    So Nixon your question is answered !!
    Cosmic023
  6. Venom1969
    Venom1969
    So you're saying that spdif is the same as co-ax?
  7. aeronic
    aeronic
    Feb 29, 2004
    55
    spidif is digital - either optical or coax.
    my SR4200 has 2 of each, and so does the 4300
  8. trevor g
    trevor g
    Hi Nixon,
    SPDIF is an acronym, it covers BOTH co-axial and optical digital types of connection.
    To give it it's full title it stands for Sony-Phillips-Digital-IterFace,after the two companies who jointly developed it.
    So yes this mean that it does.
  9. Venom1969
    Venom1969
    Thanks trevor g, it's a little bit more clear now. My laptop has an spdif output in the form of a 2.5mm jack. How would you connect this to a co-ax or optical?
  10. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Venom:
    Are you sure it's a 2.5mm jack ?? As you can get an optical lead with an optical / 3.5mm plug for £20 or less.
    If it is a 2.5mm jack then i'm not sure what you can do about this ??
  11. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
