Answered Does the Marantz NR1506 have HDMI 2.0a inputs?
Discussion in 'Home Cinema Buying & Building' started by Geoff_W, Dec 28, 2016.
    1. Geoff_W
      Geoff_W
      Nov 2, 2005
      212
      +21
      Can't seem to find a definitive answer to this question. The online manual doesn't say, Richer Sounds say "No", but Marantz Europe Technical Support say "Yes". The online manual for the NR1607 7.1 Channel Atmos model specifically states that the HDMI inputs support v2.0a and HDR. As I will want a slimline receiver that can support 4k UHD Premium HDR, this information is critical.
    2. Best Answer:
      Post #2 by unreel, Dec 28, 2016 (1 points)
    3. unreel
      unreel
      Dec 25, 2008
      620
      63
      Manchester
      +273
      Best Answer
      The product description on Marantz Uk site seems to say it does supports HDR / 4K
      Marantz UK | NR1506
      "Latest HDMI Connectivity; HDCP 2.2 Compatible
      Featuring 6 HDMI inputs, including 1 conveniently located on the front panel, the NR1506 incorporates an advanced video section that features the latest HDMI specifications, including support for 4K Ultra HD 60 Hz full rate video, 4:4:4 Pure Color sub-sampling and 21:9 video pass-through, along with support for 3D content. The NR1506 also features HDCP 2.2 compatibility, a requirement for 4K Ultra HD copy-protected content.
      The NR1506 also features Audio Return Channel (ARC), which lets you stream audio from your TV via a single HDMI connection (no need for a separate digital audio cable).
      Full Specification 4K Ultra HD Compatibility
      In addition to handling 4K Ultra HD 3840 x 2160 resolution, the NR1506 also features HDR (High Dynamic Range) and Wide Color Gamut compatibility, key components of the BT.2020 4K Ultra HD video specification."
    4. Joe Fernand
      Joe Fernand
      Jan 20, 2002
      28,330
      The Borders
      +3,424
      The 'definitive' answer is you should ignore any mention of HDMI Version numbers as they mean nothing.
      HDMI :: Manufacturer :: Trademark and Logo
      Look for the Features you require along with support for the Video and Audio signal formats your Sources Output.
      Joe
    5. Geoff_W
      Geoff_W
      Nov 2, 2005
      212
      +21
      @unreel, @Joe Fernand - Thanks for your helpful comments. The information on the Marantz UK site is definitive enough for me to go ahead with a purchase.
