Question Does The LG OLED W8 Have Same Performance As The Others?
Discussion in 'LG TVs Forum' started by AlwaysHeadFirst, May 28, 2018.
  1. AlwaysHeadFirst
    AlwaysHeadFirst
    Jun 9, 2013
    27
    Does the LG W8 have the same performance compared with the C8?
    So is picture quality, input lag and brightness the same?
  2. fat jez
    fat jez
    Jan 6, 2007
    3,656
    2
    Glasgow
    +885
    Yes. Only the B8 has lower performance .
  3. AlwaysHeadFirst
    AlwaysHeadFirst
    Jun 9, 2013
    27
    Ok, thank you for the reply.
    Do we have any tests for B8 v C8?
  4. fat jez
    fat jez
    Jan 6, 2007
    3,656
    2
    Glasgow
    +885
    I've only seen reviews of the C8. As you go up the price range you get the sets that have separate control units and soundbars. However, all from the C8 up use the same panel and electronics.
    The B8 won't be bad, it just won't have quite the same processing power as the C8 .
