Does the HD1 cradle work with later models, such as HD5?
Discussion in 'Headphones, Earphones & Portable Music' started by Gemini-Phoenix, Aug 14, 2005.
  1. Gemini-Phoenix
    Gemini-Phoenix
    Jun 23, 2005
    391
    Ipswich
    +13
    I was wondering. The Sony HD1 came with a separate cradle. What was the purpose of this cradle? Was it a charger AND USB link to the PC?
    If so, does it work with the HD3?
    I enquired to Sony about obtaining a cradle of sorts for the HD3, but they said they didn't do one for that model, which is a shame, because the link that the HD3 comes with is a bit low-tech. I'd much prefer a cradle.
  2. AlexGarfield
    AlexGarfield
    i like cradles too, alway ya it was for charging and usb. it will not fit the nw-hd3 (hd3 is a little wider) or nw-hd5 (diff jack),
    you should search the fourm first, this question has been asked many times
