Does the guide handle channel number changes?
Discussion in 'Microsoft Windows' started by sniff, Jul 21, 2005.
  1. sniff
    sniff
    Jun 15, 2005
    153
    +7
    Evening,
    I tried to record "Fat Actress" tonight - for the girlfriend, honest :D - and I've realised that Channel FX (on Sky) has changed from 289 to 270 (since I scheduled it to record at least).
    Downloading the latest guide doesn't correct this, and while looking into it I noticed that the MCE guide is completely missing channels like Vegas 24/7 and Vegas Live.
    I know I can edit the channel number manually, but that doesn't seem right! And adding the missing channels isn't the best either because the actual shows listings aren't downloaded.
    Is the guide from Microsoft just out of date, and it'll eventually get fixed?
    Anyone else had this? I'm not too fussed at the moment, but what if something good like E4 changes number!!
    I'm worried this could be quite a "show stopper" - excuse the punn ;)
  2. sniff
    sniff
    Jun 15, 2005
    153
    +7
    Have I broke some kind of forum etiquette? Apologies if I have.
    Think this is the 2nd or 3rd time I have posted and no-one responds.
    Surely someone out that has the same problem I have described?
  3. Ch0pper
    Ch0pper
    Mar 31, 2005
    246
    +3
    When selecting VH1 mine actually selects MTV2.
    Been trying to record that rock idol thingymajig but with no joy.. I want to record Reno911 on FX too.. Thanks for the reminder :)
  4. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Sniff , out of curiosity what TV card are you using?
  5. sniff
    sniff
    Jun 15, 2005
    153
    +7
    It's a Hauppauge PVR 150 MCE. Would that affect anything?
    I even tried reconfiguring the guide last night, i.e. enter post code again, and still no difference.
  6. Goodoldbakes
    Goodoldbakes
    May 3, 2005
    393
    The Edge Of Sanity
    +46
    Can I just ask a thicko question here? I have Sky set as my channel 6 (BBC1 = 1, BBC2 = 2 etc etc). When recording from Sky I use the Sky EPG to autoview and set the corresponding record time manually in MCE.
    My thicko question is - Can I set up the MCE EPG to display all the Sky channels and if so, how do I do it???
  7. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    You need to input to the s-video/composite input on the TV tuner card (plus audio). Then run MCE setup & specify that you are using a set top box.
  8. Goodoldbakes
    Goodoldbakes
    May 3, 2005
    393
    The Edge Of Sanity
    +46
    Thanks for that. Not sure if I'll be able to do that as my MCE PC and Sky box are at opposite ends of the house, connected via RF. Would a splitter and an RF to Svideo connector work do you think?
