Does the Denon AVR-2801 support RGB pass through?
Discussion in 'AV Receivers & Amplifiers' started by Confucius, May 24, 2001.
Tags:
  1. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    No, I don't think any A/V amp does. Some support component though (incl HDTV signals).
  2. tbibic
    tbibic
    Sep 3, 2000
    47
    Brighton
    cheers wise man.
    SO how on earth are you supposed to take advantage of the onscreen menus if you bypass the amp for your video connections?
    [ 24-05-2001: Message edited by: tbibic ]
  3. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    I think the theory is that you use a simple composite signal to set the amp up, then revert to bypassing with RGB for the rest of the time.
  4. tbibic
    tbibic
    Sep 3, 2000
    47
    Brighton
    As it says in the title, if I hook up all my AV gear through the AVR2801, does it support RGB pass through?
