Does the Arcam DV88 output NTSC in PAL50
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, May 3, 2001.
Tags:
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    Born in Bristol but now in Newport, (for my sins)
    +717
    Sorry to ask so many questions, but I have just thought of something else.
    One thing I am going to miss about my Samsung 709 is its ability to output NTSC signals in PAL50.. Such that you can record it on a PAL VCR.
    There are very few models on the market which will do this, but I wonder if the Arcam will?
    Does anyone know if you can set the DV88 up for PAL50 output?
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,472
    Newcastle
    +291
    You can, but I really hope it's been improved since the original software version - it was unwatchable.
    Cheers,
    Liam
  3. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    +717
    In what way unwatchable?
    My Samsung provides 50hz PAL, buy dropping every 6th frame.
    This is almost un-noticable.. But when you get smooth panning, you can see it jump a frame ever so often...
    But atleast you could video the output.
    However, I have just realised that you can't disable Macrovision on the DV88, so this is irrelevant anyway!!
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,472
    Newcastle
    +291
    I don't remember *exactly* what the symptoms were, but I think it had continuously stuttering video and sound. I think it would also freeze up. It wasn't a fairly bad picture, it wasn't a very bad picture - it was unwatchable.
    Like I say, though, this was one of the first batches of players (I borrowed it for the weekend from my local Sevenoaks when they first arrived). It may be better now.
    Cheers,
    Liam
