Does the American Xbox only support 110V?
Discussion in 'Xbox Forums' started by Kain, Jun 13, 2002.
  1. Kain
    Kain
    Jun 11, 2002
    243
    16
    Dubai
    Or does it also support 220V?
  2. Ten
    Ten
    Jul 1, 2001
    163
    16
    UK
    hiya
    afaik, there isn't a switchable power supply on the xbox, but that shouldn't be a problem, all you require is a powerful stepdown convertor (approx 150w minimum).
    ten
