J
John Langton
As the title says and if it does is there any benefit of using banana plugs instead or the open wire just pushed in and then tightened?
John
John
In some parts of the EU, the mains sockets use 4mm round pins. As a result, in their infinite wisdom, the EU decided to ban the use of 4mm plugs and sockets on audio equipment, so as to prevent the normal operation of natural selection. Naturally, the Japanese largely couldn't care less about this, so they use banana plugs and sockets on their equipment, and then block up the sockets if they are selling the product in the EU. Thankfully, most of them (like Denon) do so in a fashion that doesn't prevent you unblocking the sockets and using them.Colgate7110 said:Anyway, so as to avoid going OT on this one, why do they fit those inner parts to the binding posts if they ultimately just get in the way? I've not had a look at the speaker binding posts since the first hellish time I tried to screw the cables in and don't relish the thought of having a look to find out why it's there![]()
John Langton said:Thanks now I just need to get info on a good set of banana plugs. Im going to make my own speaker cable with CAT5 cable
spl23 said:In some parts of the EU, the mains sockets use 4mm round pins. As a result, in their infinite wisdom, the EU decided to ban the use of 4mm plugs and sockets on audio equipment, so as to prevent the normal operation of natural selection. Naturally, the Japanese largely couldn't care less about this.....
