does the 2805 take banana plugs?
Discussion in 'AV Receivers & Amplifiers' started by bogie, Aug 9, 2005.
  1. bogie
    bogie
    Jul 21, 2005
    72
    Hi Guys,
    Just checking, does the 2805 take banana plugs for the speaker connections.
    I checked last night but didn't think it looked like it does.
  2. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    You need to pop out the little bungs that are in the speaker terminals. A small flat head screwdriver will do the trick. :)
  3. spl23
    spl23
    Jan 9, 2004
    2,669
    103
    +385
    My 2805 (and 3805) came with small plastic sleeves in the speaker terminals, rather than the little caps I'd seen in the past. The easiest way to get them out is by screwing a small woodscrew half a turn or so into them, until it bites, and then using the screw to pull them straight out.
    (I should point out that I only realised this 6 months after I bought my 2805, having bought a large pile of new banana plugs the day before I picked up the amp. I therefore spent 6 months with 79-strand cable precariously hanging out of the Denon's rather flimsy screw terminals. Just how foolish did I feel when I finally realised the sleeves were removable? ;-) )
  4. stevos
    stevos
    May 16, 2004
    5,979
    +541
    Don't worry, you won't be the only one.
    I didn't realise my 3802 could accept banana's until almost a year.
