I'm considering embarking on the purchase of a Denon DVDA1 with pal progressive output. But my final decision lies with my projector's (VW11) ability to accept a pal progressive signal. Can anyone tell me if it does or not? There's no mention of it in the manual. Thanks Jules
Just found this thread using the search facility! Does the VW10HT also take a 625p signal? I'm trying to decide whether to have my DV88 upgraded to a DV89.
It most definately does, a friend of mine has a 10HT and its PAL Prog image looks great. Jules The combination you are thinking of is what I am using and I am very pleased with the results on a 7ft wide screen. A1 is great player. Phil
Hi, this thread looks like its been dug up from some time ago and I've actually had my DVDA1 and VW11 for some time now. It is a great combination, and the VW11 does accept pal prog. If I'm honest though, I don't think there's much to choose between the deinterlacer in the A1 and VW11. The DVDA1 is great but so is the VW11. If you like the VW11, I reckon you may be more than happy with the performance from a cheaper player in interlaced mode. Jules
