Does Sony HX510 support Videoplus
B
BennytheBall
I own a HX710 which supports Videoplus, I was using the 510 recently and I couldnt find any Videoplus support on it. Is that the case ?
On the 710, you just press Timer, and when it comes up with the normal programming mode, you push left, and it switches to Videoplus code entry page. This doesnt happen on the 510 and couldnt find any config setting to enable it.
TIA
grd2
If the 510 was a "D" version, ie freeview, they do not have videoplus. At least my D710 doesn't.
JayCee
Videoplus doesn't work with Freeview.
B
BennytheBall
I dont think its a freeview model, how would I know.?
Living in Ireland, we dont get Freeview so not sure how to check.
JayCee
Did you read the post from grd2?
